Technik > Tech-Talk Design & Konzepte
Lummerland with 2xel84
JTM:
--- Zitat von: Dirk am 13.07.2020 16:02 ---Hier schon mal ein Bild vom Bub
--- Ende Zitat ---
Stark, bin gespannt! Mit NFB?
Leadman:
2x6v6 Lummerland is here!
Leadman:
What is the purpose of R14(220k) in the phase inverter of the LummerLand? This resistor don´t exist in the original Blues Express el84 desing.
It´s the first time I see that resistor in a cathodyne phase inverter and I am curious about it.
Maybe it attenuates the signal before de push pull triodes? because the original desing use pentode tubes and not triode....
iefes:
R14 provides the grid of the cathodyne with a (self-adjusting) bias voltage. Typically the value would be 470k to 1M. Indeed, I would have guessed that the values of R14 and R28 are actually swapped. This would yield a more typical setup but to be honest I'm not very familiar with those small dual-triode push-pull stages and I'm sure Dirk knows his stuff :topjob:
Leadman:
Ah! the r28 acts like a grid stopper for prevent blocking distortion in that desing, and maybe de r14 has been lowered to 220k for match with the push pull triode power section.
Thanks!
Navigation
[0] Themen-Index
[*] Vorherige Sete
Zur normalen Ansicht wechseln
