Technik > Tech-Talk Amps
Harley Benton GA5 Tube Town mod II - some questions
larsthestrat:
thanks for your reply.
I can see everything in the schematic, so I'm using the schematic for most of the things. Only the heater questions stays. I don't see that in the schematic (I think a technician would....), so I was using the pics for that.
I imagine you won't help me any further considering you're last post?
grtz lars
Dirk:
--- Zitat von: larsthestrat am 2.02.2009 15:22 ---I imagine you won't help me any further considering you're last post?
--- Ende Zitat ---
Well, I don't know what else I should write. Everything is in the schematic and the pin-numbers are listed on the datasheet for the 12AX7 and / or EL84 (marked with F = filament). It is absolutly simple, just like a bulb. Check it out closely again - also the datasheet !
Best regards, Dirk
larsthestrat:
thanks Dirk for your help, I figured it out already. Just drillng some holes and it should work.
larsthestrat:
Everything works properly! and it sounds nice! thanks for all the help.
connected pin 4/5 of the socket together and wired it to cap c12 and did the same with pin 9.
I still would like to perform some extra mods which I'm not certain if they can be performed after adding this extra gainstage. At this site (http://www.ultimate-guitar.com/forum/showthread.php?t=481701&page=6&pp=20) on page 6 of 15 call1800ksmyazz adds a pentatode/triode switch. He explains what he has done at his post on 1-10 at 8.55 pm (post 114). Is it possible to perform this mod having done the TTE mods?
I want the overdrive to sound a little bit more creamier/saturated) and I'm interested in doing this mod.
Any comments?
regards,
Lars
Dirk:
I did not read the mentioned posting but basicly it is possible to add such a switch regardless if you modded the preamp or not.
Best regards, Dirk
Navigation
[0] Themen-Index
[*] Vorherige Sete
Zur normalen Ansicht wechseln
