Technik => Tech-Talk TT-Projekte => Thema gestartet von: Paulo3 am 8.06.2017 12:58
Greetings.
I bought a Jim kit from tubetown, I've almost finished it, and now I just realised my speaker cabinet has an impedance of 4 ohms, I don't have a lot of understanding on electronics, so I wold like to know if I can use this 4 ohms speaker with the Jim amp, by wiring the output transformer in a different way than showed in the diagram.
Thanks, and sorry for posting in English.
Originally it is wired with yellow/black on the secondary to get 5k ist o 8R. To keep the 5k seen on the primary with 4R, you need to take the green/black wires on the secondary instead. Then you're fine.
Cheers,
Laurent
Thank you so much for your help. :topjob:
Greetings from Switzerland .
Salut!!
Just another question...
I,ve been wathing this diagram:
Hammond 125 BSE:
(https://www.dropbox.com/s/5qbo0jsw7l4pqvm/hammond125-se.gif?dl=1)
I was wondering if I could wire as output, all the 3 ¹/4 sockets each one with its own impedance like this:
(https://www.dropbox.com/s/dt6uekoeshqxzpy/ttJIMoutput.png?dl=1)
Thanks In Advance.
Works.
Cheers,
Laurent
Thank you ! :topjob:
Just ensure that you use only one at a time...so connecting a 8 AND a 16 Ohm Box doesn't work, it's either one
Ok, I understand that.
Thanks
Cheers.
Greetings.
I just finished the assembly of my tube town Jim amp kit.
I fired it up with my guitar hooked up and a 4 homs speaker at the output, for this I used the green /black wires from the hammond OT. and it worked.
This is my first tube amp build, I really love the way it sounds, however I steel have a few questions:
I turned all the knobs all the way up except the master, and it doesn't distort a lot, I was waiting far more distortion... Then I decided to measure all the voltages marked in the diagram for comparing and they don't match...
I need help
The red values are my readings from the spot in the diagram to the ground in the chassis, all the tubes in the sockets, my guitar at the input and a 4 homs speaker at the output:
(https://www.dropbox.com/s/lwni8lt622xlfs1/minhas%20medidas.jpg?dl=1)
Can anyone tell me if these values are acceptable.
Thanks in advance.
Paulo
All these voltages are looking really low in comparison to the given values for me.
Did you measure the heater voltage with the AC function of your Multimeter? If you didn't, this would at least the reason for the over 50% to low measured heater voltage.
Maybe it could help, if you would give a picture of the power supply. Which mains voltage do you have, and which transformer primary did you connect?
Good luck,
Rattle
Hello RattleHead, thanks for your answer.
For measuring the heather, I used the AC reader.
I Live in Switzerland, main voltage here is 230 v ??? I think...., I used the violet and black wires from the primary of the power transformer.
Some pictures:
Power supply:
(https://www.dropbox.com/s/c3fitcdorb2ego2/IMG_20170615_174700.jpg?dl=1)
General view:
(https://www.dropbox.com/s/y6hle649ecn271n/IMG_20170615_174553.jpg?dl=1)
Thanks.
it looks to me like you did not connect pin 4 and 5 (marked blue) of the preamp tubes (marked red).
This could be the problem for the heater voltage issue.
The rest is ard to check, because there is no layout PDF of the Jim online, only the schematic.
Rattle
Sorry for the huge pictures...
In fact those pins are connected, I ve bent the wire and soldered them together this way.
Thanks for your help, guess I have to debug it all starting from the power supply.
Thank you.
Greetings.
Paulo
I have to ask this: the original values in the Jim diagram were measured with the tubes plugged in, or without the tubes?
Thanks
The values only make sense with tubes plugged in. You wouldn't read anything at the cathodes without tubes ...
According to the very low heater voltage: did you measure to ground or between pins 4/5 and 9 at the tubes? The latter is the right methode.
John
John
Greetings John
Your right the cathods wouldn't have any current without the tubes... ::)
And for the heathers I measured between the pins 4/5/9 and ground, that's the wrong way... :-\
I'm such a noob,thanks for making this clear to me.
As for the others values what's your opinion?
Thanks.
what's your heater voltage AC between 4/5 and 9? If it is still far from 6.3V:
maybe check to proper cleaning of the heater supply wires before soldering them. They have a brownish insulation lacquer on the surface, that has to be scraped off.
VG
Andreas
Sorry, but I don't have any opinion on that; I didn't exactly have a close look. The voltages are far to low, especially at V2b. Are you sure about those 86V? 186V would be more conclusive (but still far to low). I'd check the whole construction and have a close look at all resistor values and don't forget the PSU.
@Andreas: the amp is running in a kind of way; it won't do that without working heaters.
John
Just wanted to double-check.
VG
Andreas
86 V at the V2b is OK. Please see the updated schematics with the reference voltages.
Best regards, Dirk
Kurz OT, aber @Dirk:
Ist es Absicht, dass das Layout vom Jim nicht mehr verfügbar ist?
Jannis
Natürlich nicht, das liegt an den sch... Einstellungen
Ist wieder da.
Nur so:-) Dankschön!
Hi.
In fact the value I read between the two green wires from the heater is 6.3 v~.
I'm sorry for my mistake.
According to the new diagram provided, my values aren't too far from the real thing.
Diagram: My values:
V1a. Pin1. 134 v. V1a. Pin1. 124 v.
V1a. Pin3. 1v. V1a. Pin3. 0,98 v.
V1b. Pin6. 202v. V1b. Pin6. 197 v.
V1b. Pin 8. 60v. V1b. Pin8. 52 v.
V2a. Pin1. 173v. V2a. Pin1. 158v.
V2a. Pin3. 1,85v. V2a. Pin3. 1,72v.
V2b. Pin6. 86v. V2b. Pin6. 86v.
V2b. Pin8. 0,77v. V2b. Pin8. 0,72v.
V3 plate. 240v. V3 plate. 240v
V3 grid. 190v. V3grid. 183v.
V3 anode. 5v. V3 anode 5,38v.
My Power supply
B1. 266v
B2. 248v
B3. 197v
B2 / B3. 50v.
The values are not exactly the same , but I think they may be in the acceptable range, I just need someone to confirm this to me so that I can use my amp without worries.
Another question, when I was making the measures, I noticed that 3 of the large capacitors from the psu had current from the metallic top to ground... Is this normal?
Just want to say a big thanks to those who lost some of they're time trying to help me.
Greetings.
Paulo.
In the last post, I meant cathode instead of anode in the v3 values...
