Technik => Tech-Talk VOX => Thema gestartet von: tilma800 am Mär 05, 2013, 10:32
Titel: VOX V125 recap and retube
Beitrag von: tilma800 am Mär 05, 2013, 10:32
Hello,
I just acquired a Vox V125 amp from the early '80. It seems all looks original including the tubes and caps. i would like to recap and retube the amp to make sure all is good. Could you give some suggestions which version of the tubes I need? And where I can find the right 35mm axial caps? Nowadays, caps seem to have smaller diameter.
I do like JJ tubes, but there is to much choise  ;D Which versions woul be best for classic rock, Vox tones?
I included the schematic for reference.
It contains:
2x ECC83 (v1, v3)
1x ECC82 (v2, graphic eq)
1x ECC81 (v4, phase inverter)
4x, EL34
4x, 200uF 350V 35mm axial
2x, 32uF 450V 35mm axial
  Dennis
Titel: Re: VOX V125 recap and retube
Beitrag von: LuciMan am Mär 06, 2013, 10:49
Hi Dennis,
simultaneously with the change of C30, C31, C32, C33 you should solder a resistor 100KOhm 2W parallel to each capacitor (see pic). It keeps the voltages for each capacitor at the same level.
Claus
