Technik => Tech-Talk Amps => Thema gestartet von: Guile am 9.09.2014 14:01
Hello, Is there a guide to install the TubeTown VVR on the TT forum? I want to install it in my Reverb Deluze clone.
I really need some help. I don't want to make mistakes!
Danke
Hello,
Here You will be helped: https://www.tube-town.net/cms/?DIY/Amp-Tools/VoCo_Variable_Voltage_Control
ne schöne Jrooß, Mathias
Thanks, I read that, but I need more specific instructions if possible.
Security
Tube amps contain life-threatening voltage! Only people with
sufficient knowledge and experience should fit the VoCo to an
amp. Anything else is grossly negligent! ;)
Thanks grandpa, but where can I learn then?
Btw I built the Deluxe Reverb myself and I'm still alive ;)
Hi Guile,
Take a look at Merlin Blencowe or Morgan Jones, both wrote great books.
Merlins site: valvewizard.co.uk
Greets
Sev
P.s. what info do you miss?
Hello,
built and assembled is a significant difference in my book. Great tips from sev.
Best,
Hi Guile,
the link in the second thread should provide you with the desired info.
You could also google the "London Power scaling from Kevin o`Connor" for more info.
And the above mentioned books for shure!
Hans-Jörg
Thanks, but I got no time to read books, gotta play my guitar!
Does the 'out' coming from the pcb goes to pin 4 of one of the two 6L6 power tubes?
I just need to know where the three wires go. Let me worry about safety and being knowledgeable.
Thanks
Hello,
"out" is connected to both screen grids of the power tubes (instead of the one in the schematic https://www.tube-town.net/cms/?DIY/Amp-Tools/VoCo_Variable_Voltage_Control). Complicated, isn't id?
Mast- und Schotbruch un ne schöne Jrooß, Mathias
Thanks for helping out
Can someone explain where the B+ goes? Do I simply need to tap it of off B+?
Btw, the layout on this page is so small, I can't read it clearly: https://www.tube-town.net/cms/?DIY/Amp-Tools/VoCo_Variable_Voltage_Control
The output of the power tubes can be controlled by the voltage on the screen (G2). For this purpose, the TT-VoCo is insterted in the screen power supply.
Further questions?
The given schematic is an example how the VoCo can be used, in thr particular case in the TT66.
The page provides sufficient info about the way the VoCo works.
If, after reading this documentation, it is not clear how the VoCo is installed and used, it indicates a level of knowledge insufficient to safely and correctly install the VoCo in an amplifier. In this case, we strongly recommend letting an experienced technician do it.
Greets
Sev
Sorry, but I wonder how you managed to build your Deluxe Reverb, if you ask such questions ???
You'd better go to a professional technician. Just my 2 cents.
Axel
Proof that tube-amplifiers are not rocket-science. It's the crudest form of electronics possible; just follow the layout and pull the switch.
Every second spent fiddling in amplifiers is time lost not making music!
Just my 2 cents
Over and out.
That is your point of view and it is of course OK. But better get someone doing the job for you if you want to keep on playing guitar on earth and not somewhere else.
It is not only follow the layout and pull the switch as you can see.
Best regards, Dirk
