Hello good people,
Would it be possible to use the LNDverb-kit to drive an Accutronics/Belton digital reverb WITHOUT the use of an OT?
Greets, Frits
Please do not do this.
Best reagrds, Dirk
Best reagrds, Dirk
Thank you for your comment...
But why should it not work?
If I replace the OT with an appropriate resistor and use a coupling cap, shouldn't it do the trick?
Or am I missing out something?
Greetz, Frits
If you do that, you will have a high voltage connection to your reverb tank.
There are other ways to handle this, please do seek information on the valve wizard website
The high voltage will be separated by a coupling cap...
absolute fatal nonsens!
Maybe there is a misunderstanding
you do/must not have to use the lnd for driving a digital reverb. It is not like a reverb spring. The digital reverb unit is made for working in low voltage area and does not need a driver like a tube or a hi voltage FET together with an OT. But you can use this unit like an effects unit.
It has to be matched adeqautely regarding the level and impedance and a coupling capacitor for DC blocking, that is all. For that have a look at effect insert schematics. You can handle it like an external effects unit.
Regards
Herbie
Is that so? Please enlighten me, oh sun of knowledge...
