Problem with ABY-Switch DIY
  • 6 Antworten
  • 4597 Aufrufe
Offline abbitxuelo
  • 2
« am: 17.12.2008 09:01 »
Sorry but i don´t speak german. I wish that anybody can help me.
I mounted this aby-box  http://www.tube-town.net/diy/tt-aby/tt-aby.html
But i don't sure how solder the Xicon TM018 Audi-Transformator.
The picture is my setup, this is correct or wrong?
I have mount in this way, and i have a lot of noise in the B channel and when i connect a&b at the same time.
Can somebody help me? Thank you very much
« Letzte Änderung: 17.12.2008 09:04 von abbitxuelo »
Offline Dieter
  • 179
Re: Problem with ABY-Switch DIY
« Antwort #1 am: 17.12.2008 10:38 »
hi abbitxuelo,
the wiring looks correct to me. Did you use an isolated Jack for Ouput B?
greetings
Sebastian
haebbe58
« Antwort #2 am: 17.12.2008 13:13 »
hi abbitxuelo,
please have a look at the attachment, the file shows the complete addition of the transformer to dirk's aby-switch.
the b-output has to be isolated!
regards
haebbe
Offline abbitxuelo
  • 2
« Antwort #3 am: 17.12.2008 15:06 »
In you diagram i see that the wire 3 is solded to mass and housing, but i have the wire 2, is the same? Which is the diference? Which is wrong?
Thanks
Offline mc_guitar
  • 1.379
« Antwort #4 am: 17.12.2008 15:54 »
Hello,
If Pin3 is used in the schematic, you should also use Pin3! It is always possible that errors find their way into a schematic, but you can easily figure that out yourself.
Regards
Micha
« Letzte Änderung: 17.12.2008 15:59 von mc_guitar »
haebbe58
« Antwort #5 am: 17.12.2008 19:22 »
Pin 3 is right, it must be grounded, pin 2 should not be used ... pin 2 is the  middle tap of the primary coil and should only be used, if the source is balanced ... whe do not use balancing in this case!
So please use Pin 3, if you use Pin 2, the impedances do not match!
regards
haebbe
Offline theschramm
  • 3
« Antwort #6 am: 28.04.2012 01:25 »
