Vibro Champ Reverb
  • 40 Antworten
  • 32352 Aufrufe
sjhusting
Vibro Champ Reverb
« am: 12.02.2015 18:15 »
Ssseeeewww, meine Neuste.
Fender BF Vibro Champ, mit Hall von den PR, Merlin's 'raw' control, und ein 6SL7 V1.
Trem und Raw footswitchable mit Relays (Dirk's doppel relay board).
Cab ist Walnuss und Riegelahorn, Schwalbenschwanz, Leinoel. Ich wollte die Lautsprecher von hinten anbringen, habe aber nicht mit die Tiefe die WGS G8C gerechnet. Muss eine Loesung finden.
steven
Offline bluesfreak
  • 2.690
Re: Vibro Champ Reverb
« Antwort #1 am: 12.02.2015 18:32 »
Hi Steven
Sweeeeet!  What's your experience with the Octal PreAmp Bottle? Is it worth the space sacrificed? Bold Plates should give a bold tone, or?
let me know...
blues
Offline sev
  • 853
« Antwort #2 am: 12.02.2015 18:33 »
Hi Steven
 :topjob: :topjob: :topjob:
That cab is incredible, awesome job!
greets,
Sev
--Edward Murphy
sjhusting
« Antwort #3 am: 12.02.2015 18:54 »
Hi Steven
let me know...
blues
Hi Blues -
we'll see. I shock-mounted it - I bought an assortment of high-heat automotive 0-rings - but I'm hoping the 5 watts will be weak enough so there isn't a problem with the octal. Right now I have a Brimar in there; I also have some Ultrons (of uncertain manufacture - either Russian or British, probably Russian) - and I will eventually try RCA, GE, and Sylvania.
The amp sounds awesome.  Perfect for blues and any other "roots" music that wants to be a little dirty. I'll do a video as soon as I have time.
Building the cab was an adventure. Despite the bonehead problem with the depth, I'm pretty proud of it.
steven
Offline sev
  • 853
« Antwort #4 am: 12.02.2015 19:02 »
Hi Steven,
how much more space do you need to fit the speakers inside the cab?
greets
Sev
--Edward Murphy
sjhusting
« Antwort #5 am: 12.02.2015 19:46 »
About 5 bloody cm.
I usually cut my cabs for 25 cm depth. No idea why I went with 20 on this one.
« Antwort #6 am: 12.02.2015 20:07 »
Looks awesome.
Offline Holzdruide
  • 2.221
  • I shot the Sheriff
« Antwort #7 am: 12.02.2015 20:11 »
Sehr geile Kiste  :topjob:
« Antwort #8 am: 12.02.2015 20:56 »
Hi Steven,
pure awesomeness  :topjob: :topjob:
Cheers,
Offline sev
  • 853
« Antwort #9 am: 12.02.2015 21:29 »
Hi Steve,
what about cutting the cab in half inserting a 5-6cm stripe all the way round, probably made of another wood like cherry or something ^^
greez
Sev
--Edward Murphy
sjhusting
« Antwort #10 am: 12.02.2015 23:22 »
Yeah I thought about that. That 's the last-resort solution, because it will probably turn out badly. I have an idea to recess the speakers in the front that I want to think about first.
Germy
« Antwort #11 am: 15.02.2015 08:13 »
Hi Steve,
looks great, awesome! :topjob:
What a beautiful case. :topjob:
Greetings Germy
sjhusting
« Antwort #12 am: 17.02.2015 17:12 »
Hab Grills installiert.
Offline LöD
  • 2.348
« Antwort #13 am: 17.02.2015 17:15 »
Funktional: ja
Hübsch: nein.
Das hilft Dir jetzt natürlich nicht, ich habe auch leider keine Idee wie man die Speaker nach "hinten" verlegen könnte.
LöD
sjhusting
« Antwort #14 am: 17.02.2015 17:19 »
I have a better solution, but it is a lot of fine woodworking and will take a long time to get right. This will work fine until then.
