My SLO Clone Build
Begonnen von FourT6and2, Jun 26, 2014, 07:12
FourT6and2
Most of the power section is done. Once the preamp is wired up I can finalize the remaining connections on the power board. It's not as tidy as I really want. But there are a lot of wire runs in the SLO. Good thing they're all covered by the power PCB :) And I spliced in the lead from the OT to the HT Fuse.
FourT6and2
Elevated heater mod wired up. This part was like playing that Operation board game.
FourT6and2
Damn, power tube sockets took a long time. But they're finally done. Just need to add some heat shrink to the grid stoppers. Next steps will be the loop jacks, impedance selector, and then I can move on to the preamp board wiring and I'll be done.
mc_guitar
Hello,
Looks incredibly tidy! thumbs up for your superb work!!
Cheers Michael
FourT6and2
Output jacks, impedance selector, and FX loop return wired up. I'm not going to do the slave out. I never use it. And I can always add it later if I want to run wet/dry or something.
FourT6and2
So close!
Had to figure out a way to hold the preamp board up off the table, while at the same time keeping the lead I was soldering from falling out since they're installed from the top of the board. That's where these Helping Hands come in handy. Was pretty easy. :)
Duesentrieb
Awesome.
The slave out is useful if you want to record thru Torpedo's software. Then you can skip the power amp simulation. Just hook the amp to a load, Mike.
darkbluemurder
That's going to be an awesome amp, great build quality.
Is there a particular reason why you used the "purple wiring code"? (just kidding ;D)
Cheers Stephan
FourT6and2
Purple sounds better!
FourT6and2
Got the AC lines, Depth control, loop, and channel switch all wired up. Board is now locked in.
FourT6and2
Was out doing real-world stuff for the majority of the day. So did a couple of the small things left to do here and there: Power Board to Preamp Board jumpers for Bias, B+, and Ground; signal coax to V3/7 (not shown); and remote bias control.
FourT6and2
Yay, all done! :)
Just gotta do some testing to make sure all the voltages are good. Keeping my fingers crossed.
High Res Version: http://fc08.deviantart.net/fs71/f/2014/208/5/f/slo_clone_1_by_haftelm-d7sk7t6.jpg
FourT6and2
Powered up. No smoke, no sparks. Everything seems good. :) I think all the voltages check out for the most part. Some are a bit higher, some lower. Plate voltage is crazy high... 520 volts. Damn. Highest I've seen in any amp.
TARGET:
ACTUAL:
Laurent
Nichts ist unmöglich
Really nice job!! Looks amazing  :topjob:
Waiting for the final test: walls shaking test in the house  ;D
Is the voltage of the PI V5-pin 6 a typing mistake? Should probably be 257.9 instead of 357.9V, right?
Cheers,
Laurent
